Applying Hotfixes in NIOS (3528)
Having subscribed to the knowledge base article related to NIOS releases, you’ve received a notification from Infoblox that a hotfix is now available for a minor UI bug in NIOS, which has been annoying you for a while. The email states that there is no impact on production, but you have waited till the weekly maintenance window for hotfix installation. Now that the maintenance window is here, please proceed to install the hotfix file to GM and GMC as instructed in the email.
10 to 15 minutes
Administrative access to the Grid
Task 1: Install the hotfix file on GM and GMC
Instructions are clear to only apply the hotfix file on GM and GMC. Your file is available in xxxx folder on the jump-desktop.
Task 1 Solution: Install the hotfix file on GM
Note: The hotfix used in this lab is a simulated hotfix file provided for lab validation purposes only.
After successfully completing this lab, delete the existing lab environment and deploy a new lab before continuing with any further lab activities.
  1. Navigate to Grid→Upgrade Menu
  2. Click on the Apply Hotfix dropdown button and choose To Grid Master and Grid Master Candidates
  3. In the Apply Hotfix dialog box, click Select and open the file Hotfix-9-x-x-NIOS-75513-APPLY.bin from the Desktop
  4. Click Upload
  5. Login to GM via CLI and issue command show upgrade_history
  6. Successful installation will show the message:
    Hotfix Hotfix-9-x-x-NIOS-75513-APPLY.bin applied successfully
