Troubleshoot DHCP option filter in NIOS (3529)
A custom client has been deployed on the network 172.31.101.0/24 that requires vendor specific option (option 42), details listed in the table below. The network team has already setup the custom DHCP option space named IBDHCP, configured it with the 2 custom codes (10 and 15), and set up a filter to look for the special client IBEDU.sauron-2022_10_21.
Option Space
Option Number
Option Name
Option Type
Option Value
IBDHCP
10
Location
text
Santa Clara
IBDHCP
15
Server-IP
ip-address
198.10.9.13
However, client is not receiving these options. Please troubleshoot. You may use these 3 commands to help you on the testing-linux:
  • To enable DHCP on the testing-linux, type: sudo set-network-dhcp
  • To disable DHCP on the testing-linux, type: sudo set-network-disable
  • To clear DHCP lease on the testing-linux, type: sudo clear-dhcp-leases
  • To show the current eth2 DHCP lease information, type: sudo show-dhcp-lease
When successfully configured, the command sudo show-dhcp-lease will print out the encapsulated options as follows:
 --- Encapsulated DHCP Options (vendor_encapsulated_options)
Decoding part 1: a:b:53:61:6e:74:61:20:43:6c:61:72:61
 Option ID: 10
 Option length: 11
 Option value: "Santa Clara"
Decoding part 2: f:4:c6:a:9:d
 Option ID: 15
 Option length: 4
 Option value: "198.10.9.13"
  • 25 to 30 minutes
  1. Investigate and troubleshoot Custom Vendor Option delivery
Task 1: Troubleshoot DHCP Custom Vendor Option delivery
Check Option Space and Option Filter configuration to investigate why the Client is not getting the correct value in DHCP Option 43
Task 1 Solution: Troubleshoot DHCP Custom Vendor Option delivery
sudo set-network-dhcp command will get the client a DHCP lease, but not the correct vendor-specific options:
$ sudo show-dhcp-lease
--- Raw DHCP Lease Information
lease {
  interface "ens160";
  fixed-address 172.31.101.252;
  option subnet-mask 255.255.255.0;
  option dhcp-lease-time 43200;
  option dhcp-message-type 5;
  option dhcp-server-identifier 10.100.0.105;
  renew 1 2023/06/19 15:08:50;
  rebind 1 2023/06/19 20:53:49;
  expire 1 2023/06/19 22:23:49;
At this point, you should review the member configuration before running a traffic capture. The member configuration file (Data Management  DHCP  Member, select member, click Toolbar  View DHCP Configuration  IPv4) will show that the option space is properly setup, but in the network 172.31.101.0/24, these option values are not specified (blank).
If you navigate to the network 172.31.101.0/24, you will see that the fields under Custom DHCP Options are empty:
To properly finish the configuration, edit the network 172.31.101.0/24, click IPv4 DHCP options, under Custom DHCP Options, enter the correct values as shown below:
