Troubleshooting DHCPv4 failover in NIOS (3530)
DHCP Failover has been configured for the network 172.31.101.0/24. However, clients are not receiving leases. Please troubleshoot and fix. You may use these commands to help you on the VM testing-linux:
  • To enable DHCP on testing-linux: sudo set-network-dhcp
  • sudo password: infoblox
  • To clear DHCP leases on testing-linux: sudo clear-dhcp-leases
  • 25 to 30 minutes
Task 1: Troubleshooting DHCP failover configuration
Check DHCP and DHCP Failover configuration to understand why clients are not receiving leases as expected.
Task 2: Identifying which member granted lease
Locate lease information in the UI to identify the member that provided lease to client after troubleshooting.
Task 1 Solution: Troubleshooting DHCP failover configuration
Use the set-network-dhcp command, then look through syslog messages on both ibns1 and ibns2.
We will notice many messages indicate there are no free leases on the 172.31.101.0/24 subnet.
The GM UI shows the subnet has 0% utilization (Data Management → DHCP → Networks →172.31.101.0/24)
However, look closely, the range is disabled (grayed out).
Another way to clearly see the problem is to look at the member configuration. Choose either ibns1 or ibns2, view its DHCP configuration file, and we will see this:
subnet 172.31.101.0 netmask 255.255.255.0 {
The subnet is defined, but there is no configuration in it. This indicates there are no ranges configured. Go to Data Management → DHCP → Network →172.31.101.0/24 and enable the range, then we will see the configuration update:
	pool {
		failover peer "M1-M2(1687163233p)";
		deny dynamic bootp clients;
		infoblox-range 172.31.101.250 172.31.101.253;
Testing-linux should now be able to receive a DHCP lease.
Task 2 Solution: Identifying which member granted lease
Navigate to Data Management → DHCP → Leases → Current Leases, and we should see two lease files with the identical IP address. This is normal with DHCP Failover, for each lease, there are 2 lease files, one for each peer.
Highlight either one of the lease files and click View Lease Details.
Another way to tell is by looking at the syslog messages on both DHCP members. On the member that handed out the DHCP, we will see the normal DORA transaction; on the other member/peer, we will see DHCPREQUEST message ending with lease owned by peer.
