Creating DHCPv4 failover associations in NIOS (2515)
Your team has decided to take the first step towards DHCP service redundancy. Please create a DHCPv4 failover association, so other network administrators can leverage this redundant service.
  • 15 to 20 minutes
  • Knowledge of which Grid members will provide redundant DHCP services
  1. Creating a DHCPv4 failover association.
  2. Restarting Grid services.
Task 1: Creating a DHCPv4 failover association
Create a DHCPv4 failover association named D1-D2. Assign ibns1.techblue.net as the failover primary, and ibns2.techblue.net as the failover secondary.
Task 2: Restarting Grid services
After saving changes, you should be prompted to restart services. If not, please manually restart services.
Task 1 Solution: Creating a DHCPv4 failover association
A failover association is created by combining two DHCP servers into a failover pair.
  1. Navigate to Data Management → DHCP → Members → IPv4 DHCP Failover Associations
  2. Click on the Add (+) button
  3. This action opens the Add IPv4 DHCP Failover Association Wizard
  4. At Step 1 of 3, enter D1-D2 for Name
  5. For DHCP Failover Primary, leave the radio button set to Grid Member and click the button for Select Member
  6. Click the link for ibns1.techblue.net
  7. For the DHCP Failover Secondary, leave the radio button set to Grid Member and click the button for Select Member
  8. Click the link for ibns2.techblue.net
  9. Click Save & Close
    The following configuration is for our testing purposes in the lab environment.
    IN A PRODUCTION ENVIRONMENT, DO NOT CHANGE THE MCLT VALUE WITHOUT FIRST DISCUSSING WITH INFOBLOX SUPPORT
  10. Place a check in the box beside the newly created D1-D2 entry and click Edit
  11. Toggle advanced mode
  12. Select the Failover Settings section and click the Advanced tab
  13. Change the Maximum Client Lead Time(s) value to 300
  14. Click Save & Close
Task 2 Solution: Restarting Grid services
Changes made to the DHCP configuration only takes effect after service restart.
  1. Restart the DHCP Service by clicking the Restart button in the notification banner at the top of Grid Manager
  2. At the Restart Grid Services window, click Restart
Alternatively, we can also restart services from the Members menu by navigating to Grid → Grid Manager → Members or Data Management → DHCP → Members
  1. From the Toolbar on the right, click Restart Services
  2. Select the radio button for Force restart services
  3. Click Restart
Note that the status of the failover association will display Failure until both networks and ranges have been assigned. This behavior is expected at the end of this lab.
