Applying DNS Infrastructure Protection Profiles in NIOS (2548)
You are tasked with creating a new DNS Infrastructure Protection Profile named Authoritative – Initial Configuration. The profile will be assigned to all external-facing authoritative servers running DNS Infrastructure Protection in your organization to allow the sharing of a single tuned DNS Infrastructure Protection ruleset, instead of configuring each Grid member individually, simplifying management, ensuring consistency, and improving tuning accuracy.
Currently, your organization runs DNS Infrastructure Protection on extibns.techblue.net, with plans to add more servers in the near future.
  • 15 to 20 minutes
  • Usage of the NIOS Lab Environment (DNS Infrastructure Protection) Lab environment
  1. Create a DNS Infrastructure Protection Profile
  2. Assign Profile to Grid Member
Task 1: Create a DNS Infrastructure Protection Profile
Create a DNS Infrastructure Protection Profile named Authoritative – Initial Configuration, with default settings.
Task 2: Assign Profile to Grid Member
Assign the profile created in Task 1 to the Grid member extibns.techblue.net.
Task 1 Solution: Create a DNS Infrastructure Protection Profile
In this task, we will be creating a DNS Infrastructure Protection profile named “Authoritative – Initial Configuration“. This profile will use the ruleset 20260113-16 as its baseline. 20260526-16 is the most recent ruleset downloaded to the Grid. The profile will be assigned to extibns.techblue.net in a later step.
  1. On the jump-desktop machine, open a browser window to https://10.100.0.100.
  2. Navigate to Data Management → Security → Profiles.
  3. Click the plus (+) symbol to add a new profile.
  4. Create a new profile named Authoritative – Initial Configuration.
  5. Click Override next to the Active Ruleset Version and select the oldest ruleset 20260526-16.
  6. Click Save & Close.
Task 2 Solution: Assign Profile to Grid Member
In this task, we will apply the previously configured profile “Authoritative – Initial Configuration“ to Grid member extibns.techblue.net.
  1. Navigate to Data Management → Security → Members.
  2. Select the extibns.techblue.net member and click Edit.
  3. Under the Basic tab of the DNS Infrastructure Protection section.
  4. Select the Use profile radio button.
  5. Click Select Profile and select the Authoritative – Initial Configuration profile.
  6. Click Save & Close to save the profile setting.
  7. Publish changes when prompted.
    1. Publishing involves applying new or updated rules and configurations, including profiles or downloaded rulesets, from the Grid Master to the Grid members.
  8. The Authoritative – Initial Configuration profile is listed for extibns.techblue.net
