You are a DDI administrator for the Techblue lab environment. The DNS service instances are already running and providing recursive lookup services, and now you need to add authoritative DNS data for internal lab systems. Your goal is to configure both NIOS-X DNS servers to be authoritative for the primary forward-mapping zone techblue.net and the primary reverse-mapping zone 10.in-addr.arpa, then verify from a client that both zones return authoritative answers.
Estimated Completion Time
15 to 20 minutes
Create Forward-mapping Zone.
Create Reverse-mapping Zone.
Verify Authoritative Responses.
Task 1: Create Forward-Mapping Zone
Create a primary forward-mapping zone for techblue.net in the default DNS view and configure both DNS service instances to serve the zone authoritatively.
Task 2: Create Reverse-Mapping Zone
Create a primary reverse-mapping zone for 10.in-addr.arpa in the default DNS view and configure both DNS service instances to serve the zone authoritatively.
Task 3: Verify Authoritative Responses
Use testing-linux to verify that queries for the new zones return authoritative responses from both DNS servers.
Task 1 Solution: Create Forward-Mapping Zone
Start with the forward-mapping zone because it establishes the authoritative namespace that the lab systems will use. You create the zone in the default DNS view and assign both DNS service instances so each server can answer authoritatively for techblue.net.
Log in to your lab’s jump-desktop.
Use the Education Infoblox Portal credentials to sign in to the Infoblox Portal.
Navigate to Network → DNS.
Select the Zones tab.
Verify that the only DNS view listed is default, then click default.
Click Create and select Primary Zone.
In the Name field, enter techblue.net.
Expand the Authoritative DNS Servers section.
Select Techblue DNS Service 1 and Techblue DNS Service 2, and move them to the selected list.
Click Save & Close.
Task 2 Solution: Create Reverse-Mapping Zone
After the primary forward-mapping zone is created, create the reverse-mapping zone so the same DNS servers can answer authoritative PTR lookups for the lab IP space. Keeping the reverse-mapping zone in the same default DNS view and assigning the same service instances ensures the authoritative forward and reverse mappings stay aligned.
Stay in the default DNS view.
In the Name field, enter 10.
In the suffix drop-down to the right of Name, select .in-addr.arpa.
Click Save & Close.
Task 3 Solution: Verify Authoritative Responses
Finish by testing both zones from testing-linux. These queries confirm that the forward-mapping and reverse-mapping zones are not just present in the Portal, but are actively being served authoritatively by both DNS servers. You should see aa and NOERROR in the responses.
Switch to testing-linux and open a terminal window.
Run sudo set-network-static-bloxone. If prompted for a password, enter infoblox.
Run dig @10.100.0.110 oph1.techblue.net. A.
Run dig @10.200.0.110 oph1.techblue.net. A.
Run dig @10.100.0.110 -x 10.100.0.110.
Run dig @10.200.0.110 -x 10.100.0.110.
Review all four responses and confirm that each query returns aa and NOERROR.
