Filtering and exporting data from NIOS (1504)
Your team has added a new Extensible Attribute (EA) called Building to the NIOS Grid. Many objects have been updated with this data. Your manager asked you to send her a list of all the networks in the Building London Branch. Please use the filter and export functions in NIOS to generate this list.
  • 20 to 30 minutes
ops
  • Read-only access to Grid
Task 1: Displaying networks with city column and exporting results
Login to the GM web interface. Ensure the column Building is visible for the network objects, then create a filter to display only networks in the Building London Branch. Use the CSV export function to export all visible data as CSV.
Task 1 Solution: Displaying networks with Building column and exporting results
Login to the GM web interface. Ensure the new column Building is visible for the network objects, then create a filter to display only networks in the Building London Branch. Use the CSV export function to export all visible data as CSV.
Displaying Building column
  2. Navigate to Data Management → IPAM . In any of the columns, click the drop-down menu and select Columns → Edit Columns.
  3. Scroll down to find the Building Column and check the box to make it Visible
  4. Click Apply to save changes to the workspace
Creating a filter for networks in London Branch
  3. Click Show Filter to see filter options
  4. Create a filter using the logic of Building equals London Branch
  5. Apply the filter
Exporting visible data in CSV format
  1. Click Export button and choose Export visible data
    Read the warning message and click Start
  2. Once the export finishes, click Download
  3. The exported file can be viewed in text and spreadsheet applications
