Your organization wants some authoritative domain names to return different answers based on which subnet the DNS query originates. This calls for a DNS Traffic Control (DTC) topology-based policy. In this lab, you will create a source-based policy for the domain name webapp.dtc.techblue.net. When queried from the management networks (10.100.0./24 and 10.200.0./24), clients should receive the normal answers from Pool A. When queried from the production networks (172.31.0.0/16), clients should receive NXDOMAIN.
Estimated Completion Time
30 minutes
Lab 2606: Creating a Primary Subzone for DTC in Universal DDI
Create the source-based policy.
Create the LBDN for the source-based policy.
Test topology behavior from the client side.
Task 1: Create the source-based policy
Create a policy named Techblue Topology Policy and define the subnet-to-pool mappings used for the activity.
Task 2: Create the LBDN for the source-based policy
Create the LBDN webapp.dtc.techblue.net and associate it with the Techblue Topology Policy
Task 3: Test topology behavior from the client side
Use oph3, testing-linux, and jump-desktop to test webapp.dtc.techblue.net and confirm that each client receives the expected result.
Task 1 Solution: Create the source-based policy
This step introduces topology-based decision logic into the DTC configuration. Instead of treating all clients the same, the policy uses source networks to steer queries to different pools.
Log in to your lab’s jump-desktop.
Use the Education Infoblox Portal credentials to sign in to the Infoblox Portal.
Navigate to Network → DNS.
Expand the DTC tab and select DTC Policies.
Click Create DTC Policy.
Create the first Policy using these values:
Leave the State as Enabled.
Enter the Name as Techblue Topology Policy.
Provide Description as Source-based Policy for webapp.Choose the Load Balancing Type as Topology.
Click Next.
Click Add Pool and choose Pool A, then click Next.
Click Add Rule dropdown and choose Subnet Rule
For Name add MGMT Network Rule
For Destination choose Pool and select Pool A from Select List, then click Next.
Click Add twice and add subnets 10.100.0.0/24 and 10.200.0.0/24 then click Next and Save.
Click Add Rule dropdown again and choose Subnet Rule
For Name add Production Rule
For Destination choose Return NXDOMAIN and click Next.
Click Add and add the subnet 172.31.0.0/16 then click Next and Save
Click Finish and Save and Close.
Task 2 Solution: Create the LBDN for the source-based policy
This step exposes the source-aware policy through a client-facing DNS name. The LBDN becomes the entry point that allows DTC to apply the topology rules whenever a client sends a query.
Expand the DTC tab and select LBDNs.
Click Create LBDN.
Create the LBDN using these values:
For DNS View choose default.
Enter the Name as webapp.dtc.techblue.net.
Leave the Precedence field blank.
For Load Balancing Policy choose Techblue Topology Policy.
For Description add Monitoring service for MGMT only.
Click Save and Close.
Task 3 Solution: Test Topology behavior from the client side
This step confirms that the policy behaves differently depending on the client source. The expected result is not a simple round-robin distribution, but source-specific resolution behavior.
Log in to virtual machine testing-linux and open a terminal window
Run dig @10.100.0.110 webapp.dtc.techblue.net. A +short
Repeat the query a few times and note the responses
Confirm that testing-linux returns NXDOMAIN
Switch to virtual machine jump-desktop and open a terminal window
Confirm that jump-desktop returns NOERROR with no answer data
Switch to virtual machine oph3:
username: training
password: infoblox -
Confirm that oph3 receives Pool A IP addresses
